Lateraleinstellung beim Veritas Bevel Up Jack
Robin Lee schreibt bezüglich Veritas Bevel Up Jack *MIT BILD*
Beitrag von CONGER - The Irish diaspora in Munich »
[In Antwort auf #124469]
Hi Marcus,
Sorry for replying in English - my German is limited to being able to order Koelsch.... :)
It seems to me that what you are describing is the result of a small amount of bed skew - where the blade bed is tilted to one side or the other by a small amount. This is usually an issue with low angle planes (of any design), as the tolerances involved are very very tight. In addition, the wider the plane, the more it will become visible.
Looking at a 12 degree bed angle plane, a difference in bed height at a fixed distance from the edge of the mouth of just .0005" will require you to feed one side of the blade forward by .0025" more than the other side - which will create a visual difference in the gap between the blade edge, and the sliding toe of the plane (if the blade is projected evenly). If you set the blade parallel to the toe (visually) - you'll find that the blade does not now project evenly.
The only way to eliminate this visual gap, is to set the blade to project evenly - and then fettle (file) the edge of the toe to be parallel. I would note that this is a one time operation... once done, it does not have to ever be done again.
The good news is - this is only a visual issue, and should have no impact on the performance of your plane. If you are planing with the correct effective cutting angle for the wood you are working - a small amount of variability in the mouth opening ahead of the blade will have no impact on cut quality - sharpness and effective cut angle are the prime determinant of cut quality.
As with any Veritas product - we will stand behind it 100%... if you wish - I will be glad to replace your plane for you - just contact me directly at rlee@leevalley.com .
Cheers -
Robin Lee
Chris Scholz
Re: Robin Lee schreibt bezüglich Veritas Bevel Up
Beitrag von Chris Scholz »
Im Namen von Birma, Liberian und der USA: Entschuldigung fuer die antiquierten Einheiten die wir immer noch benutzen. Irgendwann werden auch wir uns dem "Rest" der Welt anpassen.
Rob's Masse sind uebersetzt:
.0005": 0.0005 inches = 12,7 um
.0025": 0.0025 inches = 63,5 um
Chris Scholz,
Dallas/Fort Worth, TX
Marcus Nohr
Beitrag von Marcus Nohr »
Wow,
die Hilfsbereitschaft von Dieter und die prompte Antwort von Rob Lee hauen mich aus den Socken. Vielen Dank.
Da krieg ich ja ein richtig schlechtes Gewissen, dass ich gestern nicht in die Werkstatt gekommen bin um Eure Vorschläge zu testen. Das wird auch erst am Wochenende klappen. Dann schau ich mir die ganze Sache im Licht der neuen Infos genauer an und melde mich bei Dieter und/oder Rob Lee.
Wie oben schon kurz erwähnt ist mein Problem nicht das Hobelergebniss sondern das Einstellen. Mit über die Hobelsohle Peilen komme ich nur bei Holzhobeln zurecht und wenn ich das Hobelmaul auf gleichmäßigen Lichtspalt einstellen kann hilft das doch sehr.
Vielen Dank und viele Grüße
Marcus
Re: Lateraleinstellung beim Veritas Bevel Up Jack
[In Antwort auf #124471]
Hallo Marcus,
ich hatte Dir eine E-Mail geschickt, aber sie kam zurück. Stimmt die Adresse in Deinem Profil noch? MEin Hobel ist, soweit ich das in erinnerung habe, in Ordnung.
An Marcus... Re: Robin Lee schreibt
Greetings Marcus,
ich hatte Dir eine E-Mail geschickt, aber ich habe kein Antwort erhalten. Stimmt die Adresse in Deinem Profil?
Liebe Grüße -gerard-
Marcus Nohr
Re: An Marcus... Re: Robin Lee schreibt
Hallo Forumsfreunde,
ein kurzes Update: Ich habe Rob Lee eine Email geschickt und promt eine sehr freundliche Antwort bekommen. Inzwischen ist ein Ersatzhobel auf dem Weg zu mir.
Superschenller freundlicher Service, Klasse!
Marcus
